AlKhald's avatar
AlKhald
NETGEAR MR1100-100EUS Routeur mobile Nighthawk M1
An annoying problem in the new update with NETGEAR MR1100-100EUS Routeur Mobile Nighthawk M1 It restarts every minute
  • AlKhald's avatar
    AlKhald
    Oct 22, 2019
    Hello dear brother
    Thanks and appreciation for your help
    I did all the solutions, the problem came from electricity and I did a lot of tests.
    Does not support native power after 5V update
    Which was really annoying I used Power Anker 18W
    The problem has been resolved
    The type used for the solution is
    Anker America's leading USB charging
    I also experimented
    On Samsung
    Power of 5/9 volts
    But Power Anker is the best in terms of stability
