AlKhald
Oct 17, 2019Aspirant
NETGEAR MR1100-100EUS Routeur mobile Nighthawk M1
An annoying problem in the new update with NETGEAR MR1100-100EUS Routeur Mobile Nighthawk M1 It restarts every minute
- Oct 21, 2019
Hello dear brother
Thanks and appreciation for your help
I did all the solutions, the problem came from electricity and I did a lot of tests.
Does not support native power after 5V update
Which was really annoying I used Power Anker 18W
The problem has been resolvedThe type used for the solution is
Anker America's leading USB charging
I also experimented
On Samsung
Power of 5/9 voltsBut Power Anker is the best in terms of stability
Blanca_O
Oct 21, 2019NETGEAR Employee Retired
Hi AlKhald
Welcome to NETGEAR Community!
Was it working fine before the upgrade?
Do you have the battery inserted?
Have you tried resetting the unit?
Blanca
Community Team
AlKhald
Oct 21, 2019Aspirant
Hello dear brother
I also experimented
On Samsung
Power of 5/9 volts
