TM3522
Dec 02, 2019Tutor
NETGEAR MR1100 B41
Hi, In my Iphone and some routers I have 4G+ (B41+B41 CA Combination) in My Location in my NETGEAR MR1100 this Combination does not working.. I tried select Auto mode (connect with b41...
TM3522
Dec 03, 2019Tutor
thank U for re,
yes I know that and 4G+ doesn't appear at all..
in other hand when I choose just B3 router combine it (B3+B3) and 4G+ appear
W1lliam
Dec 03, 2019Virtuoso
From this link, https://mt-tech.fi/en/netgear-nighthawk-mr1100-and-mr2100-supported-4g-ca-combinations/, it shows B41 does have CA supported for MR1100, just don’t know what went wrong when it is interacting with the tower/carrier.
- TM3522Dec 03, 2019TutorIn this link you provide me there is something important, he's talking about firmware number 12.6.3.0
I think that's mean every firmware has different carrier aggregation..
In this case I hope from netgear support team Solve this problem in next firmware.
I bought this Expensive device and It's my right not have limit as long as he support it..
Is there anyone have a solution or a way to provide me previous frimware update files to do downgrade and test them..
Thanks,
