swadeepc
Apr 03, 2019Aspirant
Netgear MR1100 Data Roaming
Hi. Have a question please. I live in Thailand but I have a sim from Singapore which I use all the time for data, as it's for work. So it's always on roaming. I use it when I travel to europe, Asia and US too. If I buy this device MR1100 and put the Singapore sim in there, will it work or do I need to set apn etc all the time? Will it be plug and play like when I have on mobile now and each country the Sim locks to the preferred mobile network and data comes automatically.
Please help.
Thanks
Swadeep
Please help.
Thanks
Swadeep
- W1lliamVirtuoso
it should work as is but yu need to make sure this sim card does support hotspot or it will be blocked when started with MR1100.
William
