SHADOW_KSA
Sep 27, 2019Guide
Netgear MR1100 dead not working
hello my router Netgear MR1100-100EUS it's keep rebooting and not working if i put battery it's not rebooting it's like dead 6 time rebooting then stop working in the video it's withou...
Sep 27, 2019Guru - Experienced User
Have you tried a different charger? it wouldn't be the first time a bad charge wasn't providing enough power to run a device. It usually takes the most power during bootup.
You also might need to reset it if its been crashing for so many bootups. Page 71-72 of the manual has options for resetting using the button or through settings.
SHADOW_KSA
Sep 27, 2019Guide
plemans wrote:Have you tried a different charger? it wouldn't be the first time a bad charge wasn't providing enough power to run a device. It usually takes the most power during bootup.
https://www.netgear.com/support/product/mr1100
i tried 3 a different charger and not work
