kGf
Dec 14, 2019Aspirant
Netgear MR1100 Frozen on data and days remaining
My netgear MR1100 is frozen on data and days remaining. Any ideas ?
kGf
Dec 18, 2019Aspirant
Thanks Guru,
Does show data and days left but has not changed for 17 days, even after recharging yesterday. Is there an easy way to factory reset ?
michaelkenward
Dec 18, 2019Guru - Experienced User
Just about everything allows that.
If you visit the support pages:
you can feed in the model number and find all the documentation for your hardware.
Look for factory reset but be warned that it wipes out your settings.
