wilburleesmith3
Mar 31, 2019Initiate
Netgear MR1100 Mobile broadband disconnected
My nighthawk m1 worked fine Friday night and I woke up to the screen saying mobile broadband disconnected. My phone (both at&t service) has 3 bars. Every once in a while it will show Default net work then Go back to the previous message. Went to settings and data is on and everything set at factory settings. I’ve factory reset it the router and changed SIM cards to no avail. Someone please help!!!
- I had to get a new sim then go into settings and select LTE ALL under network settings
- Reco6901AspirantDid you get this issue fixed? I’m having the same problem!! On two NETGEAR MR1100 hotspots both AT&T simcards !
- wilburleesmith3InitiateI had to get a new sim then go into settings and select LTE ALL under network settings
