AlvinG's avatar
AlvinG
Follower
Sep 30, 2020
NETGEAR MR1100 Mobile Router: Connect Ethernet, but still be able to use Wi-Fi Wireless
Hello All, We have a NETGEAR MR1100 (I'm pretty sure) Nighthawk wireless router. The configuration we need and what I am trying to do is: Connect and use the Ethernet port, but also be able to use the Wi-Fi wireless capabilities. I can't figure out how to configure it in the settings. Any help or input? Thanks, AlvinG
  • Hi AlvinG,
    Welcome to NETGEAR Community!
    Just like any other WiFi router, no configuration needed for Wired connection. You just have to connect the Ethernet cable into the M1 and to your device.
    As for WiFi connection, scan for WiFi Network, select network and enter WiFi Password then it should be fine.
    Blanca
    Community Team
1 Reply
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi AlvinG,
    Blanca
    Community Team
