cgigate
Jun 17, 2020Aspirant
Netgear MR1100 Nighthawk M1 no "days remaining" info shows up in Monthly Usage
There is always shows “0 Days left" from the device display and web login page. Device info MR1100-100NAS Firmware Version:12.05.05.00 and 12.06.11.00 HW version: 1.0
Blanca_O
Jun 24, 2020NETGEAR Employee Retired
Hi cgigate
Welcome to NETGEAR Community!
Please do a factory reset to see whether the data usage counter can be displayed correctly.
Blanca
Community Team
M1User
Jul 02, 2020Tutor
Several times factory reset. Limit data usage cannot be set. Billing start date cannot be set too. If it set to plan limit it will detecting service. If it set to billing start date it will detecting service too. So i keep it as it be. Billing start date let it be 1 month and plan limit let it be 0GB. if it changed the display is "Detecting Service... " so.. firmware is only to display data usage on screen but you cannot change it. Let wait developer to test and release the fix. Very annoyed.
