wenming
Jun 24, 2021Aspirant
NetGear MR1100 stopped working after Firmware update
My Netgear MR1100-2A1NAS was upgraded to latest firmware via AT&T recently. It's my backup wifi broadband device so I didn't know it stopped working until today when I tried to connect to it. I was n...
JohnPeng
Jun 25, 2021NETGEAR Expert
Hi Wen,
Could you please follow the steps below and provdie the model.json file?
1. Connect your device to your computer using USB cable
2. Log in to WebUI using 192.168.1.1
3. Navigate to URL http://192.168.1.1/model.json via the same browser window
4. Capture the results (by selecting all + copy) and send it back
Please send a private message to me with the log.
Could you please explain why you have to use ethernet port to connect to yoru computer?
Thanks
John
- wenmingJun 29, 2021Aspirant
Hi,
I sent message with the information you asked.
The reason I have to use ethernet is I'm not able to connect to the router using wireless and USB cable can only charge/power the router but not establish a network connection to it.
Ethernet is the only option I have that I can connect to the UI of the router now.
Is there any way I can reinstall the latest firmware update?
Thanks,
Wenming
