David9019's avatar
David9019
Follower
Aug 01, 2022
Netgear MR1100 stuck in Bootloop - Pls Help !!
Netgear
Model: MR1100 Nighthawk M1
H/W: 1.0
SKU: MR1100-1STAUS
My M1 stopped connecting to Mobile Network. I rebooted and that didn't not fix issue.
I took out SIM card and re-inserted and rebooted and all seemed to work ok.
Then after last shutdown at night, I did a start-up the next day and now its stuck in an endless Bootloop !
I tried to push the reset but for 10 seconds when turning on but that does not work. Any help appreciated.
1 Reply
  • Blanca_O's avatar
    Blanca_O
    NETGEAR Employee Retired
    Hi David9019,
    Welcome to NETGEAR Community!
    Did you purchase the device from your Internet provider? Kindly contact them to better isolate the issue for possible hardware problem.
    Blanca
    Community Team
