Markbird
Sep 15, 2020Follower
Netgear MR1100 vodafone broadband detected and connected but cannot get devices to connect on wifi
MR1100 Nighthawk Serial no 6AA307NP0158A currently with a 15gb Vodafone pay as you go sim. I have broadband connection to VF but cannot get any device, PC (running Windows 10) and iPad, IPhone 9/10 etc to connect. The router recognises a device or devices conected but when you search on the device nothing happens, the tmer just circles.
1 Reply
- Blanca_ONETGEAR Employee Retired
Hi Markbird
Welcome to NETGEAR Community!
If you are connected to the mobile router but cannot connect to the Internet, try the following suggestions:
• Check the display status on the LCD.
• Make sure that network coverage is available in your area.
• Make sure that your SIM card is active and enabled with data services.
• Wait one to two minutes for the mobile router to initialize.
• Confirm that your account is activated and that no other Internet connections are active.
• Switch your mobile router off and on and restart your computer or WiFi deviceRegards,
Blanca
Community Team
