galal
Jan 13, 2022Aspirant
Netgear MR2100-100EUS firmware look
Look for a software netgar m2 hanging on the company logo Netgear MR2100-100EUS
Blanca_O
Jan 18, 2022NETGEAR Employee Retired
Hi galal
Welcome to NETGEAR Community!
Kinldy take out the SIM card, reset the device, re-insert the SIM card and let it power all the way on then check for updates.
Blanca
Community Team
- galalJan 18, 2022AspirantThe router hangs on the Netgear logo and does not open at all. I need its software. I searched for it and did not find it
- Ulwa51Jan 20, 2022Aspirant
I have the same problem, the router has been hanging for a few days, but only with my Simyo card from Orange Spain. the Mr 2100 works with a card from another provider. I bought a new device and it's the same with it. maybe there was an update?
- JohnPengJan 21, 2022NETGEAR Expert
Thanks for the information. We will investigate the SIM compatible issue. Will get back to you soon.
Regards
galal wrote:
The router hangs on the Netgear logo and does not open at all. I need its software. I searched for it and did not find itPlease check whether the device can boot up with SIM card. Or do a factory reset and see whether the issule will go away.
Thanks
- galalJan 21, 2022AspirantI want to update it, thank you
