galal
Jan 13, 2022Aspirant
Netgear MR2100-100EUS firmware look
Look for a software netgar m2 hanging on the company logo Netgear MR2100-100EUS
Blanca_O
Jan 18, 2022NETGEAR Employee Retired
Hi galal
Welcome to NETGEAR Community!
Kinldy take out the SIM card, reset the device, re-insert the SIM card and let it power all the way on then check for updates.
Blanca
Community Team
galal
Jan 18, 2022Aspirant
The router hangs on the Netgear logo and does not open at all. I need its software. I searched for it and did not find it
- Ulwa51Jan 20, 2022Aspirant
I have the same problem, the router has been hanging for a few days, but only with my Simyo card from Orange Spain. the Mr 2100 works with a card from another provider. I bought a new device and it's the same with it. maybe there was an update?
- JohnPengJan 21, 2022NETGEAR Expert
Thanks for the information. We will investigate the SIM compatible issue. Will get back to you soon.
Regards
