Thomasishere
Aug 02, 2021Aspirant
Netgear MR2100 no wifi
Hi team, Mr2100 was working fine, now the wifi doesnt seem to be working - the wifi tab at the bottom of the main screeen has an X on it. i have the latest FW installed as of this date, ive factory r...
Blanca_O
Aug 06, 2021NETGEAR Employee Retired
Hi Thomasishere
Welcome to NETGEAR Community!
Please provide device SKU (MR2100-1TLAUS) and firmware version.
Using a device that is connected to the network, kindly access the router settings page, go to Settings > Wireless > "Broadcast Wi-Fi Name SSID" should be checked.
Please check as well if WiFi Standby is set to Disabled or Enabled.
Blanca
Community Team
- ThomasishereAug 06, 2021Aspirant
appreciate the effort, but is there anything else other than the basics you have mentioned? restarted, resetted several times with no improvement.
cheers - archery47Sep 07, 2021Aspirant
That option to "Broadcast SSID" under settings does not show up in the Netgear screen, Also should the WiFi Standy be set to "Disabled" or set to some time frame ....
The replies you wwre given were not specific enough and confusing ...- AyeAyeAyeSep 07, 2021ApprenticeMy M2 periodically does the same, master reset is the only thing that works.
- archery47Sep 07, 2021AspirantAppreciate the answer, but U have tried reset via pin to reset on modem, reset to factory frim Netgear website, and reset to factory from modem multiple times and none have worked..
Which one if those options SPECIFICALLY are you referring to ?
