Thomasishere
Aug 02, 2021Aspirant
Netgear MR2100 no wifi
Hi team, Mr2100 was working fine, now the wifi doesnt seem to be working - the wifi tab at the bottom of the main screeen has an X on it. i have the latest FW installed as of this date, ive factory r...
Blanca_O
Aug 06, 2021NETGEAR Employee Retired
Hi Thomasishere
Welcome to NETGEAR Community!
Please provide device SKU (MR2100-1TLAUS) and firmware version.
Using a device that is connected to the network, kindly access the router settings page, go to Settings > Wireless > "Broadcast Wi-Fi Name SSID" should be checked.
Please check as well if WiFi Standby is set to Disabled or Enabled.
Blanca
Community Team
Thomasishere
Aug 06, 2021Aspirant
appreciate the effort, but is there anything else other than the basics you have mentioned? restarted, resetted several times with no improvement.
cheers
