Thomasishere
Aug 02, 2021Aspirant
Netgear MR2100 no wifi
Hi team, Mr2100 was working fine, now the wifi doesnt seem to be working - the wifi tab at the bottom of the main screeen has an X on it. i have the latest FW installed as of this date, ive factory r...
archery47
Sep 07, 2021Aspirant
That option to "Broadcast SSID" under settings does not show up in the Netgear screen, Also should the WiFi Standy be set to "Disabled" or set to some time frame ....
The replies you wwre given were not specific enough and confusing ...
AyeAyeAye
Sep 07, 2021Apprentice
My M2 periodically does the same, master reset is the only thing that works.
- archery47Sep 07, 2021AspirantAppreciate the answer, but U have tried reset via pin to reset on modem, reset to factory frim Netgear website, and reset to factory from modem multiple times and none have worked..
Which one if those options SPECIFICALLY are you referring to ?- Blanca_OSep 07, 2021NETGEAR Employee Retired
Please provide the device SKU (MR2100-xxxxxx) and firmware version.
How many device usually connect to the network?
Kindly temporarily remove the battery and power on the device without the battery then check if it will broadcast WiFi network.
Blanca
Community Team- archery47Sep 07, 2021Aspirant
Bianca,
Thanks for that info. Tried without the battery but no success.
SKU : MR2100-1TLAUS
Firmware : NTGX24_10.17.10.00
