khaled10
Apr 24, 2021Tutor
NETGEAR MR2100
The device stops on the Net Gear logo and turns off Removing the battery did not work Attempt by cable directly without battery did not work And also with the battery it did not work Repeat this ...
- Apr 27, 2021Yes
There is no response.
Transfluxor
Apr 27, 2021Apprentice
Did you press the reset button?
