saleh86
Mar 17, 2023Guide
Netgear mr6110-1s4mes
I own an mr6110-1s4mes router, and I suffer from several problems, most notably - A large drain in the battery and heat, as the router does not last more than 6 to 7 hours only in normal use, unlik...
khanQ6r
Mar 20, 2023Initiate
Hi, I suffer from the same problem. The battery consumption does not last more than 6 to 7 hours. I add a note when choosing LTE ALL and restarting the device. A 5G signal appears on the device screen, but the network is LTE ALL. Please, we want an update that solves the problem. Thank you very much.
