saleh86
Mar 17, 2023Guide
Netgear mr6110-1s4mes
I own an mr6110-1s4mes router, and I suffer from several problems, most notably - A large drain in the battery and heat, as the router does not last more than 6 to 7 hours only in normal use, unlik...
Blanca_O
Mar 21, 2023NETGEAR Employee Retired
Hi, All,
Welcome to NETGEAR Community!
We would like to verify the following information:
- Where did you purchase the device?
- Who is your Internet provider?
- Is the M6 AC-powered on without the battery?
- Kindly login to M6 Web UI, go to Diagnostics page to check the device temperature when you think it is overheated.
Settings > Status > Diagnostics
As for the Ethernet not working with the xBox series, please make sure that Ethernet Settings is enabled.
Go to Settings > Advanced > Mobile Router Setup > Ethernet > checked 'Enable'
Did you enable Ethernet offloading? If so, kindly disable Ethernet offloading option then check xBox connection.
Blanca
Community Team
- saleh86Mar 21, 2023GuideHi, the device is Netgear from the telecommunications company stc, State of Kuwait. I sent you 4 pictures of the device’s temperature under normal use, the temperature is high, a picture of the device’s information, a picture of my device, an old update, and a picture of my friend’s device. The solutions I sent regarding the Xbox do not work. There is a general problem with the device. I expect all problems. Please update and thank you very much
https://ibb.co/WKLvVY7
https://ibb.co/MgvkpSs
https://ibb.co/d6BCsXR
https://ibb.co/d6BCsXR - saleh86Mar 21, 2023GuideEveryone has a problem with the device, as mentioned in the Netgear forum, each one and the problem that he noticed, please solve the problem. Thank you
- AhmedmelhafyMar 21, 2023InitiateYes we suffer from this problem the one that is mentions from all members, we wish you solve it as soon as possible. The device needs an update to solve all the problems.
- HadeiazmiMar 22, 2023StarBlanca_O
Power modes are just the form of the power saving or performance mode, all of them have a drain on the battery, even when changing the network mode to lte only.
It's unreasonable that the battery only lasts 8 hours and I put the power saving mode and put the grid to the lte with only 5ghz activation. - TamiAsmiMar 26, 2023InitiateDear Blanca,
I just got my Netgear m6110 and unfortunately I faced 2 problems
1) regarding the battery consumption.
2) the 5g signal is difficult to maintain.
Is there any chance that you will update the software to resolve those issues ? because I have a chance till the end of the week to return the router and buy another type.- HadeiazmiMar 26, 2023StarI went to the stc maintenance center, which is more than an hour away from my house, just for an update! Unfortunately, I got an update and it did not solve the battery and heat problems, and the wifi 160mhz option was also canceled? Why haven't the problems been solved? Why was the 160MHz option canceled?
New Firmware Version
NTGX65_10.04.23.01
