saleh86
Mar 17, 2023Guide
Netgear mr6110-1s4mes
I own an mr6110-1s4mes router, and I suffer from several problems, most notably - A large drain in the battery and heat, as the router does not last more than 6 to 7 hours only in normal use, unlik...
Blanca_O
Mar 20, 2023NETGEAR Employee Retired
Hi, All,
Welcome to NETGEAR Community!
We would like to verify the following information:
- Where did you purchase the device?
- Who is your Internet provider?
- Is the M6 AC-powered on without the battery?
- Kindly login to M6 Web UI, go to Diagnostics page to check the device temperature when you think it is overheated.
Settings > Status > Diagnostics
As for the Ethernet not working with the xBox series, please make sure that Ethernet Settings is enabled.
Go to Settings > Advanced > Mobile Router Setup > Ethernet > checked 'Enable'
Did you enable Ethernet offloading? If so, kindly disable Ethernet offloading option then check xBox connection.
Blanca
Community Team
saleh86
Mar 20, 2023Guide
Hi, the device is Netgear from the telecommunications company stc, State of Kuwait. I sent you 4 pictures of the device’s temperature under normal use, the temperature is high, a picture of the device’s information, a picture of my device, an old update, and a picture of my friend’s device. The solutions I sent regarding the Xbox do not work. There is a general problem with the device. I expect all problems. Please update and thank you very much
https://ibb.co/WKLvVY7
https://ibb.co/MgvkpSs
https://ibb.co/d6BCsXR
