saleh86
Mar 17, 2023Guide
Netgear mr6110-1s4mes
I own an mr6110-1s4mes router, and I suffer from several problems, most notably - A large drain in the battery and heat, as the router does not last more than 6 to 7 hours only in normal use, unlik...
Blanca_O
Mar 20, 2023NETGEAR Employee Retired
Hi, All,
Welcome to NETGEAR Community!
We would like to verify the following information:
- Where did you purchase the device?
- Who is your Internet provider?
- Is the M6 AC-powered on without the battery?
- Kindly login to M6 Web UI, go to Diagnostics page to check the device temperature when you think it is overheated.
Settings > Status > Diagnostics
As for the Ethernet not working with the xBox series, please make sure that Ethernet Settings is enabled.
Go to Settings > Advanced > Mobile Router Setup > Ethernet > checked 'Enable'
Did you enable Ethernet offloading? If so, kindly disable Ethernet offloading option then check xBox connection.
Blanca
Community Team
saleh86
Mar 20, 2023Guide
Everyone has a problem with the device, as mentioned in the Netgear forum, each one and the problem that he noticed, please solve the problem. Thank you
- AhmedmelhafyMar 21, 2023InitiateYes we suffer from this problem the one that is mentions from all members, we wish you solve it as soon as possible. The device needs an update to solve all the problems.
