saleh86
Mar 17, 2023Guide
Netgear mr6110-1s4mes
I own an mr6110-1s4mes router, and I suffer from several problems, most notably - A large drain in the battery and heat, as the router does not last more than 6 to 7 hours only in normal use, unlik...
Johnjony
Mar 21, 2023Initiate
Yes, it is true. I also suffer from the same problem mentioned by all the members. I add to it after there is a heat in the pocket mode, and the update is old for me. We hope to find a solution to all the mentioned problems and treat them as long as you are friendly
