saleh86
Mar 17, 2023Guide
Netgear mr6110-1s4mes
I own an mr6110-1s4mes router, and I suffer from several problems, most notably - A large drain in the battery and heat, as the router does not last more than 6 to 7 hours only in normal use, unlik...
Blanca_O
Mar 20, 2023NETGEAR Employee Retired
Hi, All,
Welcome to NETGEAR Community!
We would like to verify the following information:
- Where did you purchase the device?
- Who is your Internet provider?
- Is the M6 AC-powered on without the battery?
- Kindly login to M6 Web UI, go to Diagnostics page to check the device temperature when you think it is overheated.
Settings > Status > Diagnostics
As for the Ethernet not working with the xBox series, please make sure that Ethernet Settings is enabled.
Go to Settings > Advanced > Mobile Router Setup > Ethernet > checked 'Enable'
Did you enable Ethernet offloading? If so, kindly disable Ethernet offloading option then check xBox connection.
Blanca
Community Team
Hadeiazmi
Mar 21, 2023Star
Blanca_O
Power modes are just the form of the power saving or performance mode, all of them have a drain on the battery, even when changing the network mode to lte only.
It's unreasonable that the battery only lasts 8 hours and I put the power saving mode and put the grid to the lte with only 5ghz activation.
