saleh86
Mar 17, 2023Guide
Netgear mr6110-1s4mes
I own an mr6110-1s4mes router, and I suffer from several problems, most notably - A large drain in the battery and heat, as the router does not last more than 6 to 7 hours only in normal use, unlik...
Hadeiazmi
Mar 28, 2023Star
Hello mcuadrado
The battery is very bad and lasts only 8 hours, whether I change to low power mode or make the LTE network, and my use is very light, just browsing The device has a very high temperature, and I cannot bear to put it in the pocket, compared to the M5 The network port does not work with the Xbox unless the AC battery is removed and the ethernet speed is reduced to 100mbps - I went to maintenance and updated NTGX65_10.04.23.01 and it still suffers from the same previous problems and the vht160 option that supports wifi 6 160mhz was removed
before the update
https://ibb.co/Z89hmy9
After the update
https://ibb.co/1fDvVGV
before the update
After the update
mcuadrado
Mar 28, 2023Guide
Hi Hadeiazmi ,
let´s break the topics
#1 for battery lasting time 8 hours could you describe your scenario, how many clients are you using via wifi and via Ethernet ?
Can you share diagnostics page on the device in your most common uses case , here http://192.168.1.1/index.html#settings/diagnostics.
Please share the complete page details, actually you maybe need to scroll down to take 2 screenshots
Please note according to our internal testing as per our manual , page 60 , I would like to compare with your scenario with this , that´s reason of above questions
# For device temperature , can you also share the scenario, and share the diagnostics page and if possible share your environment and location of the device when you notice that.
# For the Xbox, Im testing here with my Xbox one, selecting Performance power mode and Xbox is working fine, Im downloading the lasts update, can you verify that selecting performance mode works for you ? in Balanced mode the Giga port is off in the M6 by design . Again , our recommendation for gaming scenarios using Ethernet port is maybe use the M6 as a fixed router , removing the battery and power it with the provided power adapter, as explained in previous post.
# About 160 Mhz channel width, Im working internally to have a new firmware to make this feature available again for customer selection. will update you soon.
Thanks for your post and I'm happy to have a personal remote session with you if you consider.
Regards1
