saleh86
Mar 17, 2023Guide
Netgear mr6110-1s4mes
I own an mr6110-1s4mes router, and I suffer from several problems, most notably - A large drain in the battery and heat, as the router does not last more than 6 to 7 hours only in normal use, unlik...
Hadeiazmi
Mar 28, 2023Star
Hello mcuadrado
The battery is very bad and lasts only 8 hours, whether I change to low power mode or make the LTE network, and my use is very light, just browsing The device has a very high temperature, and I cannot bear to put it in the pocket, compared to the M5 The network port does not work with the Xbox unless the AC battery is removed and the ethernet speed is reduced to 100mbps - I went to maintenance and updated NTGX65_10.04.23.01 and it still suffers from the same previous problems and the vht160 option that supports wifi 6 160mhz was removed
before the update
https://ibb.co/Z89hmy9
After the update
https://ibb.co/1fDvVGV
before the update
After the update
Hadeiazmi
Mar 28, 2023Star
Hi mcuadrado
the battery: The device is experiencing battery drain. My use is very simple. Just browse like Instagram and Twitter. There is only a highly connected device s22. Sometimes it does not last up to 7 hours. The power modes are just a form, there is no difference, they are all all, there is a terrible drain
Ethernet:
When I run the router on battery the ethernet connects to the xbox for 5 minutes then disconnects and this repeats - When connected to wifi, it works normally and smoothly On removing the battery the problem recurs and requires that I reduce my ethernet speed to 100mbps for it to work normally
All my friends confirmed that there is a problem with the battery, heat, and the ethernet port compared to the netgear m5
Diagnostics:
https://ibb.co/Q9Qw73Q
https://ibb.co/PZypB7C
https://ibb.co/zs7FDFP
Ethernet:
Diagnostics:
