saleh86
Mar 17, 2023Guide
Netgear mr6110-1s4mes
I own an mr6110-1s4mes router, and I suffer from several problems, most notably - A large drain in the battery and heat, as the router does not last more than 6 to 7 hours only in normal use, unlik...
Hadeiazmi
Mar 28, 2023Star
Hi mcuadrado
the battery: The device is experiencing battery drain. My use is very simple. Just browse like Instagram and Twitter. There is only a highly connected device s22. Sometimes it does not last up to 7 hours. The power modes are just a form, there is no difference, they are all all, there is a terrible drain
Ethernet:
When I run the router on battery the ethernet connects to the xbox for 5 minutes then disconnects and this repeats - When connected to wifi, it works normally and smoothly On removing the battery the problem recurs and requires that I reduce my ethernet speed to 100mbps for it to work normally
All my friends confirmed that there is a problem with the battery, heat, and the ethernet port compared to the netgear m5
Diagnostics:
https://ibb.co/Q9Qw73Q
https://ibb.co/PZypB7C
https://ibb.co/zs7FDFP
Ethernet:
Diagnostics:
