fromtimestamp
Apr 24, 2023Aspirant
Netgear mr6110-1s4mes
Could you plz tell me which bands MR6110-1S4MES supports? Moreover, Does the MR6110-1S4MES support 5G SA? JohnPeng Much thanks!
JohnPeng
Apr 24, 2023NETGEAR Expert
3G: B1; B2; B5 B8
LTE: B1, B3, B7, B8; B20, B28, B38, B40, B41, B42
5G: n1,n3, n7, n8, n20, 28, n38, n40, n41, n71, n77, n78
SA is supported.
Thanks
- fromtimestampApr 24, 2023AspirantI am currently planning to return to China. I have a telstra customised M6 in my hand. Excuse me, is the SA of this machine enabled? If it is not enabled, when will it be launched? In addition, I also want to know the 5g CA combination of M6 and m6 pro customised by telstra. Thank you very much! JohnPeng
- JohnPengApr 24, 2023NETGEAR Expert
Telstra M6 doesn't have SA enabled in the current release. We are testing a maintenance release with Telstra now. In the MR release, SA will be enabled. Based on the current schedule, we are targeting to release the MR in early June.
Thanks
- fromtimestampApr 24, 2023AspirantI also want to know the 5g CA combination of M6 and m6 pro customised by telstra. Thank you very much! JohnPeng In addition, can I apply to become a volunteer to participate in the internal test of the firmware, so that my M6 SA can be enabled in advance?
