fromtimestamp
Apr 24, 2023Aspirant
Netgear mr6110-1s4mes
Could you plz tell me which bands MR6110-1S4MES supports? Moreover, Does the MR6110-1S4MES support 5G SA? JohnPeng Much thanks!
fromtimestamp
I am currently planning to return to China. I have a telstra customised M6 in my hand. Excuse me, is the SA of this machine enabled? If it is not enabled, when will it be launched? In addition, I also want to know the 5g CA combination of M6 and m6 pro customised by telstra. Thank you very much! JohnPeng
JohnPeng
Apr 24, 2023NETGEAR Expert
Telstra M6 doesn't have SA enabled in the current release. We are testing a maintenance release with Telstra now. In the MR release, SA will be enabled. Based on the current schedule, we are targeting to release the MR in early June.
Thanks
- fromtimestampApr 24, 2023AspirantI also want to know the 5g CA combination of M6 and m6 pro customised by telstra. Thank you very much! JohnPeng In addition, can I apply to become a volunteer to participate in the internal test of the firmware, so that my M6 SA can be enabled in advance?
