Banditor's avatar
Banditor
NETGEAR MR6110 gets very hot
Regarding the Netgear MR6110,
I noticed that the device heats up too much in my opinion (this has been since I purchased it)
At first I thought it might be a problem with the battery heating up so I decided to turn it on directly from the type c connection, but the device is still really hot
I tried to save the energy consumption and the device still does not help
* No more than 3 devices are connected to it at the same time
*I changed to only 2.4gh
* Even when there is almost no data usage at all, the device is still hot
I checked for a firmware update - it seems that there is no update
My current firmware is - NTGX65_12.01.16.01
Has anyone else experienced this problem and managed to fix it?
