teddy0
Feb 27, 2023Follower
NetGear MR6500 and unRAID
I'm building a small mobile network out of an MR6500 and Beelink SEi12 mini PC connected via Ethernet. I'm running unRAID 6.11.5 and this allows me to run a Plex Docker image; I set the whole thing u...
michaelkenward
Feb 27, 2023Guru - Experienced User
teddy0 wrote:
I'm building a small mobile network out of an MR6500 ....
While many questions about routers are generic and could be answered anywhere, some things need specialist knowledge.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Mobile Routers, Hotspots & Modems
Those things are very different from the standard Netgear routers covered in this section.
You might like to search there for messages related to your problem.
I will ask the Netgear moderator to move your message.
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware. Look at the label on the device for the model number.
Check for various troubleshooting tips.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
