Kadicha
Aug 08, 2024Follower
Netgear MR6500 Battery not holding charge
Ever since I opurchased this unit in Dec 2022 the battery charge does not hold and even when not used after a day or two the battery will be empty. Is this a problem with the device, the battery or maybe the way I am closing it down?
Thanks
1 Reply
Batteries are a constant refrain around here.
Did you try this:
Search Results | NETGEAR – Battery charge
Easily overlooked.
Just another user with time on their hands.
