Workyard
Feb 17, 2026Aspirant
Netgear MR7400 (M7 Pro) hotspot + Intel BE201 WiFi card
I’m having a strange compatibility issue with a Netgear MR7400 (M7 Pro)-unlocked hotspot and a Windows laptop with an Intel BE201 Wi-Fi 7 card. The laptop can see the 5 GHz and 6 GHz networks but get...
Feb 17, 2026Guru - Experienced User
What version of windows are you on?
If EVERYTHING else connects fine but one device, its usually the one device. Not saying its a hardware issue, just that it could be a device issue. Windows 10 didn't support wifi 7 and I"m not sure at what point windows 11 did. Might be part of the wpa2 reason it works
