Workyard
Feb 17, 2026Aspirant
Netgear MR7400 (M7 Pro) hotspot + Intel BE201 WiFi card
I’m having a strange compatibility issue with a Netgear MR7400 (M7 Pro)-unlocked hotspot and a Windows laptop with an Intel BE201 Wi-Fi 7 card. The laptop can see the 5 GHz and 6 GHz networks but get...
Workyard
What actual driver are you installing?
- Intel WiFi-7 BE201 320Mhz from the intel website
The auto-install driver or the one from intel?
- I removed the manufacturers drivers, went to the Intel website and downloaded the latest drivers.
What version is it?
- 24.20.04 (Jan 6th 2026)
Are you using wpa2/wpa3 mode?
- Using WPA3, I do NOT see either 5G or 6G bands
- Using WPA2, I see the 5G and 6G bands
Thanks.
Feb 23, 2026Guru - Experienced User
Try Setting Preferred Band on the Intel Adatper under it's Advanced Settings...2.4Ghz only. Maybe set Preferred Mode as well.
Workyard wrote:What actual driver are you installing?
What version is it?
