NeilCroft91
Apr 21, 2020Tutor
Netgear night hawk m1
I have accidentally switched my device from 2.4ghz to 5ghz on my app, however my mobile phone cannot find the hot-spot now and i cannot connect back to the app to change it back without being connecte...
JohnPeng
Apr 21, 2020NETGEAR Expert
The easiest way is to do a factor reset by pressing the reset button near the micro-SD slot.
Or you can follow the steps below:
1. Connect the device to your computer using USB cable
2. Open Browser and visit 192.168.1.1
3. Log in as admin with the password printed on the product label.
4. Change the settings as you wish.
NeilCroft91
Apr 21, 2020Tutor
Can you please be a little more detailed after i login on that Web page please thank you :)
