Flappie23
Sep 29, 2022Tutor
Netgear Night Hawk MR5200 cant find service.
Hi, I have a problem with a few Night Hawk M5s. Non of them are connecting to an LTE network. I've tried differed Sim cards and carriers . After reading the forum, I think this might be a firmwar...
W1lliam
Sep 30, 2022Virtuoso
have you checked if APN settings done correctly for the SIM card you are trying?
- Flappie23Sep 30, 2022Tutor
Yes, I've uses the sim cards in other devices and used the same APN.
I have this problem on 3 Night hawk m5s. None of these devices can find any network in a manual search. First I thought the antenna might be broken but this would be strange if it happens to all 3 at the same time. After some digging on the internet, I found this might be a firmware issue. So I would like to upgrade or downgrade manually to try and fix the problem. Do you know how to go about this. I cant find any firmware online.
- skids25342324Sep 30, 2022Guide
This is 100% a firmware issue, either modem wise or device wise. My m5 was working with the 3 big networks in the US, ATT verizon and t-mobile until it updated and now it's doing nothing but showing 000-00 and mobile network disconnected. It also shows 100EUS on it though it's a 100NAS model. The lack of providing any easy way to update this brick is testing my patience.
- Flappie23Oct 03, 2022Tutor
I agree. The fact I'm experiencing this problem on multiple Night hawk M5, says enough. The interface lets me pick my own firmware to update. But there is no firmware to be found online..
