MidnightMerc
Sep 27, 2024Aspirant
Netgear Night Hawk MR5200 No Service
I have the MR5200-100NAS and it cannot get a signal with any carrier. I had tried Verizon, TMobile, and ATT SIMs and all three are not working in my device. I have also verified that the SIMs work in...
MidnightMerc
Nov 01, 2024Aspirant
Thanks for responding!
On the screen, there are two prompts:
First
APN Setup Required
To connect to the Internet, please setup your APN.
Second
Mobile Broadband Disconnect
Your data connection is disconnect
The admin page show a prompt as soon as I login:
APN Setup Required
Please select an APN or click on submit button to create a new APN
There is a drop list with two options:
vzwinternet
vsblinternet
I tried both and it just shows Searching. The same SIM in another MR5200 (that works fine) APN shows vzwinternet
The signal strength shows Excellent and has a Service Number.
The device was purchase through Netgear directly and not a shop so I believe the device is unlocked.
Not sure what else to do here. Any suggestions is appreciated.
rcpax
Nov 01, 2024Luminary
Try the suggestions on this post: https://community.netgear.com/t5/Cell-Service-Mobile-Hotspot/How-To-Use-a-VERIZON-Nano-Sim-with-the-NETGEAR-MR5200-Mobile/m-p/2217693
This sounds like a persistent problem with Verizon.
- MidnightMercNov 01, 2024Aspirant
Actually just did this after doing another Factory Reset. Same issue: Just shows Searching and no broadband connection. Also tested the SIM in my other MR5200 and it's working fine which was previously using a T-Mobile SIM.
- rcpaxNov 01, 2024Luminary
what specific steps did you do? If you have a T-Mobile SIM, try that in your "problematic" hotspot and see if it works. If it does, then you know it's Verizon blocking your SIM from being used in that hotspot. You can't do much if the carrier will not let you connect to their network. Verizon is known to do this. That is why I stay away from them.
I did a Factory Reset through the web page. Then I set the APN on the screen as the steps in your link had indicated. The T-Mobile SIM is doing the same as the Verizon SIM -- just shows no connection and searching. Both are being blocked?
