aabbaa
Apr 21, 2020Aspirant
Netgear Nighthawk - constant reboots
Hi, I have the MR1100EE model running the latest firmware (NTG9X50C_12.06.03.00). My device randomly resets without reason during the day, it always comes back but it is quite irratating as the netwo...
aabbaa
May 08, 2020Aspirant
I've used 3 different chargers (Standard charger, Apple charger + Qualcomm Quick Charger 3.0). The device randomly reboots itself on all 3.
I went out and bought a huawei box as it's the only other one which covers the nearby spectrums that I could get at a good price. It hasn't reset at all yet and uses the same SIM + power source.
I would prefer to use the netgear router as I get higher throughput on the download speed, so if anyone can suggest a potential fix it would be appreciated. Or suggest a way that I can get to the device logs and see why it is rebooting.
