Marcus1981
Feb 28, 2021Tutor
Netgear Nighthawk firmware update
I took a netgear nighthawk m1 firmware update on Thursday Night and now it does not show my data usage like it should: https://prnt.sc/109mh9r so Please fix it! I have restarted the modem took the si...
Thinchy
Mar 02, 2021Initiate
I have the same issue. No data showing after latest update. This is a loss of one of the good features of this router.
Marcus1981
Mar 02, 2021Tutor
Yeah Im thinking about doing a factory reset, so it will work again! If they dont fix it in a few days!
- Marcus1981Mar 02, 2021Tutor
Well I did a factory reset and it didnt remove the latest firmware update!
- michaelkenwardMar 03, 2021Guru - Experienced User
That's right. A reset clears the settings. It does not wipe out the firmware.
With routers and other modems there are ways of getting back to oder versions.
- Marcus1981Mar 03, 2021Tutor
I dont know how to go back to the last firmware update! Im hoping they fix the current one so it reads the sim card data correctly!
- thechuckApr 29, 2021Aspirant
Yes, doing a factory reset does not affect the firmware as the firmware is burned into memory.
I just updated my firmware today and am now getting the same annoying no graph.
Where is the fix?
