Marcus1981
Feb 28, 2021Tutor
Netgear Nighthawk firmware update
I took a netgear nighthawk m1 firmware update on Thursday Night and now it does not show my data usage like it should: https://prnt.sc/109mh9r so Please fix it! I have restarted the modem took the si...
Marcus1981
Mar 02, 2021Tutor
Yeah Im thinking about doing a factory reset, so it will work again! If they dont fix it in a few days!
Marcus1981
Mar 02, 2021Tutor
Well I did a factory reset and it didnt remove the latest firmware update!
- michaelkenwardMar 03, 2021Guru - Experienced User
That's right. A reset clears the settings. It does not wipe out the firmware.
With routers and other modems there are ways of getting back to oder versions.
- Marcus1981Mar 03, 2021Tutor
I dont know how to go back to the last firmware update! Im hoping they fix the current one so it reads the sim card data correctly!
- ArodiDMar 03, 2021NETGEAR Expert
Hi Marcus1981 ,
We have confirmed the issue is on Telstra's end and are working with them to urgently rectify.
- thechuckApr 29, 2021Aspirant
Yes, doing a factory reset does not affect the firmware as the firmware is burned into memory.
I just updated my firmware today and am now getting the same annoying no graph.
Where is the fix?- Marcus1981Apr 29, 2021Tutor
Still no fix for At&T been this way since the firmware update! So I just check my data on my account with at&t!
