Starsurfer55
Jan 27, 2022Aspirant
Netgear Nighthawk low temperature operation
I upgraded my old 4GLTE nighthawk last year to a 5g nighthawk through AT&T. This is in my RV and I use it for business purposes during the SUmmer months. During the WInter months, there is no use e...
Jan 27, 2022Guru - Experienced User
You can try taking the battery out.
If you look in the user manual, its operating range is from 32 degrees F to 95 degress F.
Its more about the chemistry of the battery and how it looses effeciency in lower temps to the point of not working. You see a lot of outdoor battery powered cameras run into this same issue. Even companies like Arlo disable charging in cold temps to prevent damage to the battery.
- Starsurfer55Jan 29, 2022Aspirant
Thanks. I will try taking the battery out.
