Starsurfer55
Jan 27, 2022Aspirant
Netgear Nighthawk low temperature operation
I upgraded my old 4GLTE nighthawk last year to a 5g nighthawk through AT&T. This is in my RV and I use it for business purposes during the SUmmer months. During the WInter months, there is no use e...
Jan 27, 2022Guru - Experienced User
You can try taking the battery out.
If you look in the user manual, its operating range is from 32 degrees F to 95 degress F.
Its more about the chemistry of the battery and how it looses effeciency in lower temps to the point of not working. You see a lot of outdoor battery powered cameras run into this same issue. Even companies like Arlo disable charging in cold temps to prevent damage to the battery.
Starsurfer55
Jan 29, 2022Aspirant
Thanks. I will try taking the battery out.
