JorgeSRT's avatar
JorgeSRT
Follower
Mar 27, 2022
Netgear Nighthawk LTE Mobile Hot spot Router
Can I add a Ubiquiti Unifi Enterprise system to the MR1100 to create a mesh network in a stadium environment?
1 Reply
  • plemans's avatar
    The MR1100 has its own routing capability.
    Can you add another routing setup to it? yes. You'd just want to put the mr1100 in passthrough mode or the ubiquiti in access point mode.
