Georgiana
Jan 04, 2019Follower
Netgear Nighthawk M1 - data connection problem
MR1100 - Dear netgear support, I am writing because you are the last chance to fix the product otherwise I will have to throw it away. I have several problems, but the most important is that the devi...
Mexoh1To7k
Jan 11, 2019Apprentice
I have a made a script that automatically push the data button if you want, it succeeds at reestablishing the connection within a second. You need a computer for monitoring though.
You have Iliad, which is the company that operates Free Mobile in France. They have set a maximum time to live of 12 hours for the PPP sessions and the MR1100 fails to reestablish the connection after the hang up.
It's not difficult to fix but Netgear doesn't seem to care very much about it.
Lemme know if you want the script.
Truster
Mar 23, 2019Aspirant
Est-ce que ce serait possible que vous publiez ce script pour que d'autres personne (dont moi) pouvions l'utiliser ?
Ce serait tres sympatic.
