Georgiana
Jan 04, 2019Follower
Netgear Nighthawk M1 - data connection problem
MR1100 - Dear netgear support, I am writing because you are the last chance to fix the product otherwise I will have to throw it away. I have several problems, but the most important is that the devi...
nokiahelp
Apr 23, 2019Tutor
Mexoh1To7k hello, I'm interested in the script too :D
Mexoh1To7k
May 05, 2019Apprentice
Hi,
Sorry for that long delay. I have attached the script.
Just adjust the 'ip' and 'pwd' variables to reflect your MR1100 and keep the script running.
This is a python 3 script.
#!/usr/bin/python3 import requests import json import time import datetime ip = "192.168.1.1" pwd = "admin" url_session = "http://{}/sess_cd_tmp".format(ip) url_js_token = "http://{}/js/NetgearStrings.js".format(ip) url_config = "http://{}/Forms/config".format(ip) url_json = "http://{}/api/model.json".format(ip) url_json_success = "http://{}/success.json".format(ip) url_success = "http://{}/index.html".format(ip) timeout = 3 first_run = True def router_reachable(r): global first_run try: s = r.get(url_session, timeout=timeout) first_run = False if s.status_code != 200: raise ValueError("Wrong status code") print("Connect OK.") except: print("MR1100 unreachable. Wrong IP?") exit(1) def login(r): try: r.get(url_session, timeout=timeout) except: print("Connection failed. Wrong IP?") time.sleep(2) try: js = r.get(url_js_token, timeout=timeout).text global token token = js.splitlines()[11].split()[1].strip('"') data = { 'token': token, 'err_redirect': '/index.html?loginfailed', 'ok_redirect': '/index.html', 'session.password': pwd, } except: print("Token computation failed.") login_success = False try: redirect_url = r.post(url_config, data=data, timeout=timeout).url if redirect_url == url_success: login_success = True else: print("Failed to authenticate, incorrect password?") exit(1) return login_success except: print("Connection failed.") def get_status(r): try: json_model = json.loads(r.get(url_json, timeout=10).text) status = json_model['wwan']['connection'] return status except: print("Cannot retrieve connection status.") def reconnect(r): try: disconnect = { 'token': token, 'err_redirect': '/error.json', 'ok_redirect': '/success.json', 'wwan.autoconnect': 'Never', } connect = { 'token': token, 'err_redirect': '/error.json', 'ok_redirect': '/success.json', 'wwan.autoconnect': 'HomeNetwork', } push = r.post(url_config, data=disconnect, timeout=timeout) push2 = r.post(url_config, data=connect, timeout=timeout) if push.url != url_json_success: print("Failed to disconnect.") elif push2.url != url_json_success: print("Failed to reconnect.") except: print("Connection failed.") def main(): r = requests.Session() if first_run: router_reachable(r) login(r) status = get_status(r) if status != "Connected": reconnected = False while not reconnected: reconnect(r) time.sleep(5) status = get_status(r) if status == "Connected": timestamp = datetime.datetime.now() s = "Reconnect successful {}".format(timestamp) reconnected = True print(s) time.sleep(2) if __name__ == '__main__': while True: try: main() except KeyboardInterrupt: exit(0) except SystemExit as e: exit(1) except: time.sleep(2) main()
- nokiahelpMay 05, 2019Tutor
Mexoh1To7k Many thanks !
Maybe a stupid question but the script needs to run on a PC connected to the router, right ?
Is it possible to execute the script on an android device (like a tablet) ?
Thanks again :)
- Mexoh1To7kMay 05, 2019Apprentice
Yes, the machine on which you run the script must have access to the web interface of the MR1100.
Android generally doesn't ship with Python, but there's a terminal emulator called Termux that seems to include it. Feedback appreciated.
OK, thank you
I've installed Termux but there is a problem when importing requests (and maybe the two others). Please see the screenshoot in attachment
