Georgiana
Jan 04, 2019Follower
Netgear Nighthawk M1 - data connection problem
MR1100 - Dear netgear support, I am writing because you are the last chance to fix the product otherwise I will have to throw it away. I have several problems, but the most important is that the devi...
Mexoh1To7k
May 05, 2019Apprentice
Yes, the machine on which you run the script must have access to the web interface of the MR1100.
Android generally doesn't ship with Python, but there's a terminal emulator called Termux that seems to include it. Feedback appreciated.
nokiahelp
May 05, 2019Tutor
OK, thank you
I've installed Termux but there is a problem when importing requests (and maybe the two others). Please see the screenshoot in attachment
- Mexoh1To7kMay 05, 2019Apprentice
Try running "pip install requests" from the terminal.
- nokiahelpMay 05, 2019TutorYep it's working I guess : "Connect OK." and then command prompt (I can write a command).
I'll let the script running on my phone during night and see tomorrow morning.
Thank you again, and good night !- Mexoh1To7kMay 05, 2019Apprentice
Yes, it means that it's working.
It will prompt a message when a reconnection occurs followed by the date and time.
