Georgiana
Jan 04, 2019Follower
Netgear Nighthawk M1 - data connection problem
MR1100 - Dear netgear support, I am writing because you are the last chance to fix the product otherwise I will have to throw it away. I have several problems, but the most important is that the devi...
Mexoh1To7k
May 05, 2019Apprentice
Try running "pip install requests" from the terminal.
nokiahelp
May 05, 2019Tutor
Yep it's working I guess : "Connect OK." and then command prompt (I can write a command).
I'll let the script running on my phone during night and see tomorrow morning.
Thank you again, and good night !
- Mexoh1To7kMay 05, 2019Apprentice
Yes, it means that it's working.
It will prompt a message when a reconnection occurs followed by the date and time.
- nokiahelpMay 06, 2019Tutor
Right ! As you can see on my screenshoot (see attachment) your script is running fine on Android.
Thank you very much !
- Mexoh1To7kMay 06, 2019Apprentice
Great.
See also, the few connection errors are usually due to wireless congestions.
