Georgiana
Jan 04, 2019Follower
Netgear Nighthawk M1 - data connection problem
MR1100 - Dear netgear support, I am writing because you are the last chance to fix the product otherwise I will have to throw it away. I have several problems, but the most important is that the devi...
nokiahelp
May 06, 2019Tutor
Right ! As you can see on my screenshoot (see attachment) your script is running fine on Android.
Thank you very much !
Mexoh1To7k
May 06, 2019Apprentice
Great.
See also, the few connection errors are usually due to wireless congestions.
