Georgiana
Jan 04, 2019Follower
Netgear Nighthawk M1 - data connection problem
MR1100 - Dear netgear support, I am writing because you are the last chance to fix the product otherwise I will have to throw it away. I have several problems, but the most important is that the devi...
elmheeer
May 18, 2019Aspirant
Hi. I've got some problems with my data connection too. I can only get 3G or H signal. Before I can get a 4G connection now I don't know what happened. I can't anymore get a 4G connection with my Saudi internet sim. Tried to use the sim in other mobile hotspot/router and the sim can get a 4G connection. I hope you can help me if somehow you resolve yours. Thanks
