MickK's avatar
MickK
Initiate
May 03, 2017
Netgear Nighthawk M1 - Ethernet port defaulting to OFF on bootup
I have this device sitting ontop of a small server rack to provide fast remote access (vs fixed line ADSL)c. The unit is being run without battery in a server room cooled to 20 degrees celcius.
It will sometimes reset during the day, at which point i can walk downstairs and tap the power button once to wake up the Ethernet port. However I can't always be onsite to reset the Ethernet port and sometimes the unit resets at night.
Is there a temperature protection feature that is causing the unit to reset? I have disabled WIFI to reduce power consumption in the hopes this will prevent random resets.
Is there an option to set the Ethernet port to default to ON on bootup?
Related - does anyone know how long until a firmware update to enable IP Pass-Through wil be available? I have an internet load balancer behind the nighthawk with a dynamic dns feature built in, but it will only trigger on ip address change on the WAN port of the load balancer.
Cheers, M.K.
  • DarrenM's avatar
    DarrenM
    Sr. NETGEAR Moderator
    Hello MickK
    I have sent you a private message.
    DarrenM
